Adding DID allowed on free edition?
Discussion in '3CX Phone System - General' started by ryan, Sep 4, 2007.
  1. ryan
    Aug 27, 2007
    35
    Hi.
    I am playing around with the 3CX software using the free edition.
    Now when I add a DID (I got a test one from VirtualPhoneLine), and I have to add IP addresses of the originator.
    I couldn't see where to put the IP addresses supplied from the DID provider so I set the source to Anywhere, but I get the following in 3CX logs:
    [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '64.246.22.119'; From: '780089xxxx'; To: '101'; Rline: '101'; Contact: '780089xxxx'
    The xxxx is just covering my mobile number!
    I thought by setting the Source as anywhere the call should get through.
    Advice appreciated.
    Cheers
    Ryan
  2. ryan
    Aug 27, 2007
    35
    Please ignore - I altered the general settings to allow direct SIP dialing and it all springs into life.
    Learning every day!
    Cheers,
    ryan
