adding extensions during installation
Discussion in '3CX Phone System - General' started by t4mack, Jun 15, 2010.
  1. t4mack
    Jan 19, 2010
    56
    The ability to import extensions during installation.
  2. carolinainnovative
    May 4, 2009
    369
    5
  3. t4mack
    Jan 19, 2010
    56
    I just figured the ability to do it while installing would have been nice. That way all you have to do is configure outbound rules. and Digital receptionist. Didn't mean to make you angry.
  4. carolinainnovative
    May 4, 2009
    369
    5
    my sincerest appologies if you detected anger in what I wrote. None was intented. I simply was asking if that was not sufficient - because I didn't know if you were aware of that feature.
    I have actually wondered why they bothered with the add extension bit in the install. It seems like it makes more sense to just add extensions in the web interface - because it isn't like you aren't going to have to go there and do things as you suggsted... you'll still have to configure outbound rules, setup providers and/or gateways, etc...
