Adding extensions
Discussion in '3CX Phone System - General' started by andrewseni, Dec 18, 2012.
  1. andrewseni
    Aug 14, 2008
    17
    Probably a totally dumb question, but...
    Trying to install 3CX version 9 (the last version I can get to install under XP Pro). The software talks to the SIP provider OK, but when I try to add an extension, the only IP address available in the drop-down box is that of the system itself, so I can't add any extensions.
    I can ping any address on the network and the system shows up on the network correctly.
    What am I doing wrong?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    Don't you want the phone extensions to talk to the phone system - and it in turn it communicates with the SIP Provider?
    I am not familiar with v9 - but I expect behind the scenes, it does the same thing.
  3. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    Just for the note: XP SP3 and version 11 work well (not offical support but it is working)...
  4. andrewseni
    Aug 14, 2008
    17
    Clearly I want the extensions to talk to the phone system, but I am not getting that far. I want to add an extension that is at 192.168.0.123 (for example). However, if I try to add an extension the only IP address I am offered is that of the XP system itself.
    I couldn't look at the Facebook links because it requested I log in to the Facebook account that I don't have (or want!).
  5. craigreilly
    Feb 1, 2012
    2,962
    180
    The IP you select IS THE PHONE SYSTEM.
    Then when you setup the phone, the IP you selected here is in the TEMPLATE SETUP FILE for the PHONE. This is the IP the PHONE USEs to CONTACT THE SERVER.
    And... 8| the Facebook links are part of my signature, not intended solely for you to help with this issue.
