Adding of photos as Admin
Discussion in '3CX Phone System - General' started by RP!, Aug 14, 2017.
  1. RP!
    RP!
    Jun 22, 2017
    19
    5
    is it possible to add photos as admin over the management console for any extension?
    The only way i knew is the webclient, but via the WC every user have to change
    the photo on his own.
    Thanks in advance,
    Rafael.
    Marco Bankers likes this.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @RP!
    Currently you need to launch the webclient to upload the profile picture for each user but if you have access to the management console then you have the login details for all extensions.
    You can post this as a feature request to our ideas section of the forum where it can upvoted by other users and evaluated by the appropriate department.
