Solved Adding participants to webmeeting via email
Discussion in '3CX Phone System - General' started by kurt5132081, May 11, 2017.
  1. kurt5132081
    May 11, 2017
    47
    I am having trouble adding participants to webmeetings via email, i get the error below any assistance would be much appreciated
    port forwaders are configured and server is accessible from the outside on the neccessary ports.
    thanks
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,580
    115
    Your PBX will also need to have a valid certificate and not a self signed one.
    You can see this by accessing your PBX and checking the top left tag on the URL browser bar and see whether it's green or red.
  3. kurt5132081
    May 11, 2017
    47
    thnak you for your reply, i will update the certificate and try again.
  4. kurt5132081
    May 11, 2017
    47
    worked like a charm thanks
