Adding VOIP/PSTN Gateway Screen
Discussion in '3CX Phone System - General' started by schampeau, Mar 3, 2013.
  1. schampeau
    Mar 3, 2013
    I just add a new PSTN gateway for the Goldstream HT-701. My analog line is on-hook, registered, and working fine calling between stations. The question I have is should there be an entry showing in VOIP/PSTN Gateway screen? If so, would this then allow to create an outbound rule so I can select my pots line for dialing out?
    I at release 11
    Regards,
    Steve
    10,356
    224
    The Grandstream HT-701 is a single line ATA (analogue telephone adapter). It is not a gateway It allows you to use a standard analogue telephones on a VoIP PBX.
    To place a call to an "outside" phone, you will need either a VoIP trunk, from a provider, or, a Gateway to connect to one of several interfaces, PSTN (standard phone line). ISDN BRI or ISDN PRI. You would then add the trunk(s) to 3CX and create outbound rules to route calls.
    The Grandstream HT-503 contains both an ATA and a gateway, as does the Cisco/Linksys SPA-3102.
  3. schampeau
    Mar 3, 2013
    Thanks for clearing up my confusion. :S
    I was basically trying to create a loop start trunk off the system using the HT701 device.
  4. schampeau
    Mar 3, 2013
