Addition settings for initial provisioning of phones.
Discussion in 'Ideas' started by cgm, May 17, 2017.
  1. cgm
    cgm
    Aug 31, 2009
    11
    3CX doesn't want partners to modify provisioning of the templates. It would help if there were at least a couple additional settings for provisioning. Along with time zone, add 12 or 24 hour format. Add a switch that would turn on or off missed call notifications. Ask partners what other features they should be able to control.
    Thanks,
    Chris
