Additional fax extension
Discussion in '3CX Phone System - General' started by Spyklee, Jan 27, 2009.
  1. Spyklee
    Nov 1, 2007
    45
    Is it possible to create an additional fax extension in v7?
    The commercial version has a predefined fax extension 888.
    I would like to define an additional fax extension to setup a seperate e-mail address based on a DID-number inbound rule.
    Fax-line #1 -> sales@...
    Fax-line #2 -> support@...
    Eric
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    All you need to do is get DID numbers, and set them as fax DID and route them to the email of EXT xxx.
