Additional features via grandstream ATA
Discussion in '3CX Phone System - General' started by miro, May 7, 2012.
  1. miro
    Jan 17, 2012
    51
    i have grandstream ATA 4008 connected to the 3CX, extension is registred and inocming/outoging calls are working. What is not working is pick up call with dial codes (*20*), the phone is Siemens C590. Is there any way to fix this issue?
    Also call transfer is not working, we tried with phone manual and grandstream ATA manual but nothing... caller is still on line...
  2. GSSupport1
    Jan 3, 2012
    Hi there,
    Please edit your dial plan under profile 1 tab. Add this part into your dial plan {*xx*x+}
    Then, your dial plan probably is { x+ | *x+ | *xx*x+ } after editing.
    Thanks,
  3. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    i get information to set this value and now call transfer works like a charm ;)
    Hook Flash Timing: In 40-2000 milliseconds range, minimum:40 maximum:399
