Additions to V14 Call Reporting options.
Discussion in 'Ideas' started by bhedreen, May 3, 2016.
  1. bhedreen
    Nov 3, 2011
    When using V14 reporting function i was trying to find a way to get statistics on calls across incoming lines. Unfortunately there is not an selection for either the lines coming in from your telco or SIP provider or is there one for the virtual extensions. It would be of great help to our business office if we could provide statistics on number of calls etc. on all incoming lines individually through the V14 reporting tool. Thanks!
