Admin Panel - Connection Reset Localhost
Discussion in '3CX Phone System - General' started by alex22alex, Mar 25, 2010.
  1. alex22alex
    Jun 11, 2008
    38
    Hi All,
    Odd problem. Upon restarting our 3cx machine the system says cannot connect to localhost ( connection reset ). The window management console works fine and it seems that 3cx is functioning normally.
    Any ideas ?
    Cheers Alex
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hi Alex,
    Where do you see this error message?
  3. alex22alex
    Jun 11, 2008
    38
    Hi Mark,
    When trying to load the admin pannel via friefox/internet explorer. Using the url given in the Start Menu Link to the 3cx Managment Console i.e : http://localhost:5481 i also tried swapping localhost for 127.0.0.1 to no avail.
    Cheers Alex
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi Alex,
    send me the Cassini Metabase FIle. (Cassini Metabase.xml)
    usually you will find it under ProgramData>Ultidev>Cassini or under Document&Settings>All Users...
    Also go to Services.msc and check UltidevCassini Service if it's still running.
  5. alex22alex
    Jun 11, 2008
    38
    It was not running when i checked. File is below :
    Code:
      <?xml version="1.0" encoding="utf-8" ?>
    - <CassiningMetabase xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
    - <Application FrameworkVersion="2.0" KeepRunning="true">
      <PhysicalPath>C:\Documents and Settings\All Users\Application Data\3CX\Data\Http\Interface\myPhone</PhysicalPath>
      <Port>5000</Port>
      <Name />
      <Description />
      <DefaultDocument>index.aspx</DefaultDocument>
      <ApplicationID>7abee8ec-5ffa-23f4-b881-6441d5b7c1e9</ApplicationID>
      </Application>
      <PhysicalPath>C:\Documents and Settings\All Users\Application Data\3CX\Data\Http\Interface</PhysicalPath>
      <Port>5481</Port>
      <Name />
      <Description />
      <ApplicationID>7abee8ec-5ffa-45f4-b881-6441d5b7c1e9</ApplicationID>
      </Application>
      <PhysicalPath>C:\Documents and Settings\All Users\Application Data\3CX\Data\Http\Interface\ivr</PhysicalPath>
      <Port>5484</Port>
      <Name />
      <Description />
      <DefaultDocument>ivr_start.aspx</DefaultDocument>
      <ApplicationID>7abee8ec-6cca-45f4-b881-6441d5b7c1e9</ApplicationID>
      </Application>
      </CassiningMetabase>
  6. alex22alex
    Jun 11, 2008
    38
    If its of any consequence upon restart the webserver does not been to be loaded.
    Alex
  7. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    What version of PBX are you using? The metabase file seems correct. Can you restart the Cassini Ultidev Service? If No, does it give you an error. I beleive you have Windows Server 2003 installed?
    Also Alex, if possible send me all the logs ( Help > Generate Support Info ). Remember to have Verbose logging level on so I can have a look.
