Admin Password Reset
Discussion in '3CX Phone System - General' started by AlphaMedia, Apr 18, 2008.
  1. AlphaMedia
    Apr 18, 2008
    I just installed 3CX (Free version) today, and when I went to log into the Management Page, my credentials are not being accepted. Im assuming I mis-typed something during the install. Is there anyway to reset the PW, or do I need to un/re install?
  2. AlphaMedia
    Apr 18, 2008
    This is the full error:
    SQLSTATE[08006] [7] FATAL: password authentication failed for user "administrator"<br>#0 C:\Program Files\3CX PhoneSystem\Data\Http\functions\CallContext.php(37): PDO->__construct('pgsql:dbname=ph...', '[USERNAME]', '[PASSWORD]')<br />
    #1 C:\Program Files\3CX PhoneSystem\Data\Http\functions\CallContext.php(86): CallContext->getConnection()<br />
    #2 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fExtension.php(78): CallContext->safeExec('select DN.IDDN ...', Array, 'Cannot get Exte...')<br />
    #3 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fObject.php(90): fExtension->getData()<br />
    #4 C:\Program Files\3CX PhoneSystem\Data\Http\index.php(7): fObject->getManager()<br />
    #5 {main}
  3. arpa
    Feb 14, 2008
    35
    Do the last one
  4. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    You could also try this tool:
    http://www.utahvoipstore.com/products/189-power-tools-for-3cx-password-reset.aspx
  5. Powermage
    Powermage New Member
    Mar 19, 2008
    103
    Big kick, but for later google searches it can be nice to see this here instead of buying a tool for this.
    There is an simple way to retrieve a password.
    Create a backup of the configuration through the backup and restore tool.
    open the zip file containing the backup and look for the XML file located in the root of the ZIP and open it.
    Search for:
    Example:
    Code:
    <Parameter>
                <Value>Thepassword</Value>
                <Type>Int32</Type>
                <Description>The admin pass</Description>
                <Name>WEBSERVERPASS</Name>
            </Parameter>
    The parameter value contains the password.
  6. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    Awesome ... Just when I needed that piece of info too!
    Thanks ...
  7. abovepoint
    Aug 2, 2012
    5
    So, I cant find WEBSERVER in the document or the word admin... has this been changed or removed?
  8. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Try searching for WEBSERVERUSER for the administrator user name and WEBSERVERPASS for the password that should do the trick
    cspecs likes this.
