ADSL bandwidth allocation
Discussion in 'Windows' started by iustel, Dec 28, 2010.
  1. iustel
    Dec 28, 2010
    Hi there,
    I have a question about the bandwitch allocation using an ADSL connection. How much voip clients could I serve with a 256 kbps upload connetion? I think it's somehow related with the codec I'm cosidering to use, but it will be nice to have an average usage.
    Thanks for your help.
    Francesco.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    90% of answers are here: http://www.3cx.de/blog/bandbreitennutzung-ethernet-internet/
    the rest (10% of technical details related to ADSL) is here: http://www.3cx.com/blog/docs/bandwidth-dsl-atm-isp/
