adsl for 3cx
Discussion in '3CX Phone System - General' started by Thor2008, Jul 26, 2012.
  1. Thor2008
    Mar 28, 2009
    10
    good morning
    for a good use of 3cx 10 ( mini edition) with 10 ip phones
    wthat type of adsl performance must i have ? ( primarily upload performance)
    Thanks Alberto
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    Will depend to some degree on what your other needs are, but knowing that the mini editioon will support up to 4 calls and assuming that all 4 will be occupied at the same time with either an inbound or outbound call, most will suggest reserving between 80-100kbs on both up and down. This will also be dependent upon the codec you use and if you do a search for bandwidth or codec you will see what your options are and how much is really needed. What I provided is more a rule of thumb to make things a little easier.
    The following may help more so.
    http://www.3cx.com/blog/docs/bandwidth-dsl-atm-isp/
