Advanced call logs
wgordon
Where can we see the SIP headers in the loggers, as in previous versions?
Hello there,
You will need to generate the support files or find the logs in the C:\ProgramData\3CX\Instance1\Data\Logs directory and use the bin log viewer from a previous version.
Well THAT'S a pain! Does anyone know if there are plans on bringing back the ability to view from the web interface?!
I think that there was was an issue in the initial release, but in SP0 you can see the SIP message. Make sure through the the PBX is set to Verbose and that the services have been restarted.
file.php
Beautiful! Thank you for your tip! =) All set now! =)
Where do you set the verbose option?
You can set verbose mode by going to Dashboard >> Activity Log >>Settings >> Verbose
Getting Started - Admin
TLK
Get 3CX - Absolutely Free!
3CX
