Advice needed for Desperate Novice
Discussion in '3CX Phone System - General' started by garrycarpenter, Nov 28, 2007.
  1. garrycarpenter
    Nov 28, 2007
    20
    Advice for Desperate Novice
    I have been asked to look at 3CX as a replacement for our failing Avaya system.
    Love the idea but am not a comms guy!
    Can someone recomend a gateway to use for our ISDN30 line, I realy want one with T38 support for our fax numbers too.
    Problem I have is that I have no idea what I'm looking for.....
    HELP!
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Hi.
    Take look at http://www.3cx.com/support/voip-gateways.html
    Personaly i use Welltech with experience as very stable gateways.
  3. garrycarpenter
    Nov 28, 2007
    20
    Any Suggestions on a specific model.
    As I said, I have no idea what I am looking at.....
  4. Mori
    Mori New Member
    Mar 23, 2007
    223
    We only use VoIP, so i dont know much about PSTN gateways either.
    Think i kick the ball out to someone else on this one... :wink:
  5. alicic
    alicic New Member
    Oct 3, 2007
    119
    Hallo,
    I think you could use AudioCodes. They have the range of Products for ISDN PRI 30 channels.
    I thing the model you are looking for is Mediant 1000 VoIP Media Gateway.
    regards,
