Advice setting up 3CX with 2 x PSTN lines
Discussion in '3CX Phone System - General' started by fistameeny, Apr 25, 2017.
  1. fistameeny
    Feb 10, 2017
    8
    I'm looking to setup 3CX with 2 x PSTN telephone lines and need some advice as to the best way to do it. I have:
    • 3CX v15 running on a server (physical box, Debian, free license)
    • 3 x Yealink IP phones (T26p and W52)
    • 1 x Linksys SPA3102
    • 2 x PSTN lines (I'm in the UK, they are from BT)
    Line 1 is the main incoming number.
    Line 2 is used for outgoing calls and has an "unlimited" calls package on it.
    Ideally, I'd cancel the PSTN lines and just use VOIP, but I face large contract buy-out charges. I was then thinking to use the SPA3102 to convert the PSTN to use with 3CX, but, I'd need 2 of them, plus the paid license for 3CX (as free is limited to 1 gateway only).
    Could anyone provide guidance as to how I might set this up? I'm open to buying something different to the SPA3102 that has 2 x ports on it, if that's required, and would potentially consider a paid 3CX license (but I don't need any of the additional features).
    All help gratefully received.
  2. V..
    V..
    Feb 14, 2017
    76
    29
    Just to clarify the PBX (Free) edition of 3CX is 1 SIP Trunk only not a gateway. In order to use SPA3102 with a free version of 3CX you will need to go back to 14.
    Personally I would recommend purchasing a 3CX Standard license and a 2 line Patton gateway as this is the supported, least hassle way of achieving your desired setup.
  3. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    47
    ... sorry that's not right. You can have 1 gateway on the free edition. Just get a 2/4 port fxo gateway.
    I agree with the Patton suggestion though ;)
    ... but if you're gonna use this in production buy a licence, it's worth it !
    Artik Lal and YiannisH_3CX like this.
  4. fistameeny
    Feb 10, 2017
    8
    Thanks. So I could have 1 x SIP trunk *and* 1 x gateway on the free edition? I will definitely look to upgrade to a full license once I know I can get good value out of it.
    Would I be right in thinking, even with a gateway, that I could still only have 1 incoming call at once on a PSTN line? The gateway doesn't change the fact that I cannot receive a second call when a call is already in progress? Sorry if that's a daft question!
    Artik Lal likes this.
  5. leejor
    11,293
    361
    The Feature comparison chart https://www.3cx.com/phone-system/edition-comparison/ simply says "Supports SIP trunks/gateways---1", so I take that to mean you get one or the other, not one of each. I'm not even certain if it has been confirmed if a multi-trunk gateway is supported. It is a bit vague.
  6. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    47
    It's one or the other, and yes you can have 1 multi-line gateway and do multiple calls.
  7. fistameeny
    Feb 10, 2017
    8
    Thanks for your help. I'll try and hunt down a 2 port FXO gateway to experiment with.
