after 1 minute conettion to voip provider is down
Discussion in '3CX Phone System - General' started by ngsolutions, Jan 2, 2007.
  1. ngsolutions
    Dec 28, 2006
    8
    after registration in voip provider every think is ok, but 1 minute later connection i down a my public number don't work, but I can coll out side.
    what is the risen?
  2. npiersma
    Dec 30, 2006
    55
    I've got two voip numbers with my ISP (xs4all.nl). Got same sympthoms. I've found that it had to do with port forwarding from outside interface to 3cx server.
    If you've got the possiblity, try to enable logging on your firewall and see if packages are dropped (udp/tcp). You'll probably see 5000-10000 connections dropped when dialing the number from the outside.
    I think opening up the ports will solve part of the problem. (I am still not in the blue).
    Niels
  3. ngsolutions
    Dec 28, 2006
    8
    I have able port forwarding on 5060-5061, but still doesn't work
