After 30 seconds: "That extension does not exist"
Discussion in '3CX Phone System - General' started by birmingham, Feb 19, 2013.
  1. birmingham
    Oct 17, 2011
    Setting up new server. Recorded prompts and set up some Call Queues, Ring Groups and Digital Receptionists in 3CX. The setup appears to be intuitive.
    However, when I dial into the system from my mobile phone to test, no matter what menu items I select as a caller, after about a total of 30 seconds a system prompt recording says "that extension does not exist". My only choice is to hang up at that point.
    Any insight? Server activity log:
    15:49:46.010 Leg L:4.2[Ivr] is terminated: Cause: BYE from PBX
    15:49:46.008 Leg L:4.1[Line:10000<<12135551212] is terminated: Cause: BYE from PBX
    15:49:46.008 [CM503008]: Call(C:4): Call is terminated
    15:49:46.008 [CM503021]: Call(C:4): ACK is not received from sip:12135551212@
    15:49:21.267 Currently active calls - 1: [4]
    15:49:13.961 [CM503007]: Call(C:4): Ivr:900 has joined, contact <sip:900@>
    15:49:13.961 [CM503007]: Call(C:4): Line:10000<<12135551212 has joined, contact <sip:st9761Sxbq@>
    15:49:13.959 L:4.2[Ivr] has joined to L:4.1[Line:10000<<12135551212]
    15:49:13.841 [CM503025]: Call(C:4): Calling T:Ivr:900@[Dev:sip:900@;rinstance=dff060de391267f9] for L:4.1[Line:10000<<12135551212]
    15:49:13.829 [CM503027]: Call(C:4): From: Line:10000<<12135551212 (":5280255" <sip:12135551212@>) to T:Ivr:900@[Dev:sip:900@;rinstance=dff060de391267f9]
    15:49:13.829 [CM503004]: Call(C:4): Route 1: from L:4.1[Line:10000<<12135551212] to T:Ivr:900@[Dev:sip:900@;rinstance=dff060de391267f9]
    15:49:13.829 [CM505003]: Provider:[Nexvortex - US] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:st9761Sxbq@*ip address deleted*:5060]
    15:49:13.828 [CM503001]: Call(C:4): Incoming call from Line:10000<<12135551212 to <sip:900@>
    15:49:13.824 Line limit check: Current # of calls for line Lc:10000(@Nexvortex - US[<sip:st9761Sxbq@>]) is 1; limit is 20
    15:49:13.762 [CM503012]: Inbound any hours rule (5280255) for 10000 forwards to DN:900
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    It sounds like the selection (DTMF) made from your cell phone is not being recognized at the IVR level and a time out is occurring. Try the same thing from a land line and see what happens.
    I noticed that you use nexVortex as the SIP trunking agent. Did you use the template when setting them up?
  3. leejor
    This is troubling, and indicates that there has been a time-out waiting for a SIP message that didn't show.
  4. kevin
    kevin Member
    Nov 23, 2006
    This log line:
    ...means that your VoIP Provider connection is experiencing NAT Traversal issues. What does the Firewall Checker tell you about your firewall settings?
