After a little time -> Not registered
Discussion in '3CX Phone System - General' started by Anonymous, Nov 6, 2006.
  1. Anonymous
    Anonymous Guest
    Hi at all.
    I'm italian and I have 10 accounts with Skpho.net, a VoIP provider. Any account have a number VoIP-IN.
    If I add this Provider, and configure my 10 accounts in Number of VoIP lines (If multi-line is supported), and insert all in the next window, I see my numbers are Registered...
    ... but, after a little time, I see not registered!
    I can call out, but incoming calls not work.
    with x-lite, if I insert the same account, I see P-Registrar-Error: Too many registered contacts
    Where is a solution?
    I can't insert my 10 accounts singularly because "Proxy Hostname or IP" must have non-empty and unique value
    Regards,
    Elia Finotti
  2. Anonymous
    Anonymous Guest
    If I modify a data in one line of a provider (es. Allow outbound calls on this line: yes|no), the Phone System re-register all the lines of this provider?
    Perhaps the problem is this...
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    305
    beta 3 will have VOIP provider improvemenst
    Since we are so close to release of beta 3, i suggest to retry when we have beta 3. WE have made some improvements to the VOIP provider interface which should allow for wider compatibility with more services.
  4. mrLunkwill
    Oct 15, 2006
    7
    I had tha same problem in Beta2 - Try Beta3 it seems like the problem is solved.
    //mrLunkwill
