After activate the license 3cx doesn't work !
h2009
hmm - i wonder if your having the same problem as me, with g729 - my calls connect but no RTP packet are received.
Can you check to see if g711u calls work.
Are you sure your phones are able to use G729? What phones are you using?
Please provide more information about problem.
Provider, configuration, logs, provider capability, which version of G729 is used
We need to see SDP of incoming INVITE (from the provider)
Getting Started - Admin
NickWinker
Get 3CX - Absolutely Free!
3CX
