after change Public ip no incoming calls
Discussion in '3CX Phone System - General' started by jensnb, Mar 30, 2008.
  1. jensnb
    Mar 11, 2008
    10
    Hello this is my problem,
    i have an dynamic ip and the provider is 1und1, when the ip is changing i have no incoming calls, outgoing after stun check is ok. I must manual registering the VOIP Lines, then it ist working. Can I make this automatic after IP change?
    Here is my log
    15:20:21.296 StunClient::process [CM506003]: Resolved SIP external IP:port has changed to (84.188.44.57:5060) on Transport 10.0.0.10:5060
    15:20:21.250 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 212.227.15.200:3478 over Transport 10.0.0.10:5060
  2. jensnb
    Mar 11, 2008
    10
    The 3CX Version is 3CXPhoneSystem 5.1.4287.0
  3. jensnb
    Mar 11, 2008
    10
    the Server is behind a gateway (NAT) is this the problem?
    sorry for my bad english (german)
