After Hours Schedules
Discussion in '3CX Phone System - General' started by deichb, Mar 8, 2013.
  1. deichb
    Apr 3, 2012
    Hello group!
    I am looking for some help here. I have a licensed version of 3CX (latest updates), and we have a pretty routine after hours/on call schedule. We have three technicians that one will do Monday and Wednesdays every week, a second tech will have Tuesday and Thursday, and the last tech for Fridays. That seems pretty simple right? Well, here is the sketchy part. Each tech has the weekend every third week. Is there a way in 3CX scheduling to get this done automatically?
    Thanks for your advice and help!
    Brad
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    Given your scenario, no, I do not think so as you need something that is calendar based so that you can accommodate the "every third weekend" issue.
    You might try this however -
    http://www.voiptoys.com/products/334-3cx-on-call-manager-by-voiptoys.aspx
    I know nothing about it other than some others referencing the company and some of the products here in the forum.
