After Upgrade - No Push Notifications
Discussion in 'Android' started by AH2, Apr 13, 2017.
  1. AH2
    AH2 New Member
    Mar 14, 2017
    112
    5
    I've upgraded today, and my 3cx Client on Samsung S7 edge its acting up, freezes, its not receiving calls while on lock screen. when it does, there's no answer /reject button.
    Tried removing the app, and configuring it again, worked the first call, and then started acting up again.
    Any ideas ?
    Thanks.
    AH
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,972
    282
    Upgraded the server to 15.5. or updated to the latest client?
  3. AH2
    AH2 New Member
    Mar 14, 2017
    112
    5
    Upgraded server to 15.5, there is still no update for Android client on playstore.
  4. Nick Galea
    Jun 6, 2006
    1,972
    282
    Yes, this was an oversight on our part. Sorry about that. It should be there now and its indeed required for 15.5
