After v15 upgrade
Discussion in '3CX Phone System - General' started by pedroben, Aug 22, 2016.
  1. pedroben
    Aug 2, 2016
    10
    Hi all,
    I appear to be getting the following error after a v14 upgrade to v15. This error is triggered when i go to edit my sip trunk information. Also, i did notice that the firewal checks fails for the 3cx sip server and port 5060 full cone test however, the phones still work.
    One final thing is i can't receive any updates either. Shows as version 15.0.0 and there's no available updates.
    System is a professional edition.
    System.UnauthorizedAccessException: Value cannot be changed
    at ConfigurationManagementModel.CfgPropertyBase.set_Value(Object value)
    at ManagementConsoleJS.Services.Adapters.CmmProperyAssigner.AssignNewValue(ICfgItem item, ICfgProperty prop, Object propertyValue)
    at ManagementConsoleJS.Controllers.EditController.Update(PropertyUpdateArg vm)
    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.<InvokeActionFilterAsync>d__28.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.<InvokeAsync>d__18.MoveNext()
    at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
    at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
    at Microsoft.AspNetCore.Builder.RouterMiddleware.<Invoke>d__4.MoveNext()
    at ManagementConsoleJS.Middleware.ExceptionWrapperMiddleware.<Invoke>d__3.MoveNext()
  2. pedroben
    Aug 2, 2016
    10
    Just realised i only get this with a particular browser. Also updates show up on a different browser which is weird.
    No longer an issue
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    After any 3cx update, it is advisable to clear your cache.
  4. das
    das
    Dec 8, 2015
    14
    Besides clearing cache, use Firefox or Chrome, they show updates correctly.
