Again Callling after hanging up
Discussion in '3CX Phone System - General' started by netpet, Jun 14, 2007.
  1. netpet
    May 11, 2007
    7
    I have a Problem with the voip provider with using 3cx. When I make a call, and the other doesnt answer so I have to hang up without connection, after about 30 sec my VOIP Provider is calling the number again.
    3cx is not connecting at this, all lights are green.
    So what am I doing wrong.
    BR Hans-Peter
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    What provider are you using? Is it a supported one?
  3. dekatech
    Feb 13, 2007
    82
    Is this a call to an external extension or one on the same network as your 3cx system?
