Agent login to multiple queues
Discussion in '3CX Phone System - General' started by xrated, Jun 28, 2017.
  1. xrated
    May 16, 2017
    16
    hi
    its possible to make a blf key "Agent login/logout". If one extension is associated to 2 or more queues, will it be logged in or logged out to all of them with just one key press?
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    385
    52
    Yes. When configuring BLF keys in 3CX Management Console there is an option "Agent Login/Logout" and then you choose "OUT" or "IN". You have to make two keys one for "OUT" and one for "IN".
    Caution though this works the same as the "Q" in 3CXPhone and if the agent has manually signed out of a specific queue the "IN" won't sign them back into that queue until they sign back in using 3CXPhone to that specific queue. For more info on that check this document out under "Explicit (Selective) Login and Logout" https://www.3cx.com/blog/docs/managing-queue-status/
    accentlogic likes this.
