Agent - priority/ Skill based routing
Discussion in 'Ideas' started by OleAndreas, Jan 8, 2018.
Agent - priority/ Skill based routing 5 5 3votes
5/5, 3 votes
  1. OleAndreas
    Mar 27, 2015
    Several customers needs to qualify the agents within a group, prioritized hunt does not fulfill the request. There are +10 agents where some of the agents only is requested if there is high volume of calls.
    (I can not find the original post)
    They have moved from another system with the possibility to qualify the agents from 1 - 9; if all agents with priority 1 is busy, the agents with priority 2 is added to the ring pattern and when both 1 & 2 is busy 3 is added. etc.
    Please vote
    the60 likes this.
  2. the60
    the60 New Member
    Oct 21, 2011
    117
    61
    LOVE this idea!
  3. kieferschild
    kieferschild New Member
    Jul 1, 2016
    170
    17
    I believe this idea has already been mentioned and If memory serves me correctly, 3CX are planning on implementing this. Could 3cx confirm please?
