16:40:37.578|.\VExtMgr.cpp(78)|Log2|DataBase|FaxCfg::updateContact:[CM504008]: Fax Service: registered as sip:
[email protected]:5060 with contact sip:
[email protected]:5100;user=phone<br>
16:44:34.156|.\Authorization.cpp(368)|Error1||evt::CheckAuth::not_handled:[CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 192.168.1.5 tid=-ac45bbbe cseq=REGISTER
[email protected]:5060 / 62 from(wire)<br>
16:44:34.156|.\Authorization.cpp(323)|Log2||printDetailedInfo:[CM502001]: Source info: From: "106"<sip:
[email protected]>;tag=ba7e30bbc5f4c61bo0; To: "106"<sip:
[email protected]><br>
16:44:34.156|.\Authorization.cpp(103)|Critical0|Authorization|AuthMgr:
nAuthFailure:[CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.5 tid=-ac45bbbe cseq=REGISTER
[email protected]:5060 / 62 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings<br>
16:45:37.703|.\VExtMgr.cpp(78)|Log2|DataBase|FaxCfg::updateContact:[CM504008]: Fax Service: registered as sip:
16:45:55.718|.\Extension.cpp(310)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.102: new contact is registered. Contact(s): [sip:
[email protected]:5060/102]<br>
16:48:10.218|.\Extension.cpp(310)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.150: new contact is registered. Contact(s): [sip:
[email protected]:5060/150]<br>
16:50:00.937|.\StunClient.cpp(355)|Log2|STUN|StunClient:
nInitTests:[CM506001]: STUN request to resolve SIP external IP
ort mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.5:5060<br>
16:50:37.765|.\VExtMgr.cpp(78)|Log2|DataBase|FaxCfg::updateContact:[CM504008]: Fax Service: registered as sip:
16:51:03.125|.\SLServer.cpp(759)|Log2|MediaServer|MediaServerReporting::Service:*** Server started ***<br>
16:51:03.125|.\SLServer.cpp(759)|Log2|MediaServer|MediaServerReporting::Service:*** Exit Listen ***<br>
16:51:03.125|.\SLServer.cpp(759)|Log2|MediaServer|MediaServerReporting::Service:*** Server shut down ***<br>
16:51:05.421|.\Extension.cpp(342)|Log2||ExtnCfg::updateContact:[CM504002]: Ext.*0: a contact is unregistered. Contact(s): []<br>
16:51:05.421|.\Extension.cpp(342)|Log2||ExtnCfg::updateContact:[CM504002]: Ext.*1: a contact is unregistered. Contact(s): []<br>
16:51:05.953|.\Extension.cpp(342)|Log2||ExtnCfg::updateContact:[CM504002]: Ext.*0: a contact is unregistered. Contact(s): []<br>
16:51:05.953|.\Extension.cpp(342)|Log2||ExtnCfg::updateContact:[CM504002]: Ext.*1: a contact is unregistered. Contact(s): []<br>
16:51:09.671|.\Extension.cpp(342)|Log2||ExtnCfg::updateContact:[CM504002]: Ext.999: a contact is unregistered. Contact(s): []<br>
16:51:09.687|.\Extension.cpp(342)|Log2||ExtnCfg::updateContact:[CM504002]: Ext.800: a contact is unregistered. Contact(s): []<br>
16:51:10.203|.\Extension.cpp(342)|Log2||ExtnCfg::updateContact:[CM504002]: Ext.999: a contact is unregistered. Contact(s): []<br>
16:51:10.203|.\Extension.cpp(342)|Log2||ExtnCfg::updateContact:[CM504002]: Ext.800: a contact is unregistered. Contact(s): []<br>
16:51:11.390|.\VExtMgr.cpp(93)|Log2|DataBase|FaxCfg::updateContact:[CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone<br>
16:51:11.906|.\VExtMgr.cpp(93)|Log2|DataBase|FaxCfg::updateContact:[CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone<br>
16:51:12.343|.\MSInterface.cpp(734)|Log2||MediaServerConnected:[CM112000] Media Server is connected<br>
16:51:18.718|.\VExtMgr.cpp(78)|Log2|DataBase|FaxCfg::updateContact:[CM504008]: Fax Service: registered as sip:
16:51:20.125|.\Extension.cpp(310)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*
[email protected]:40000;rinstance=c288edc6dc952191/*0]<br>
16:51:20.203|.\Extension.cpp(310)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*
[email protected]:40000;rinstance=4ebc2dcc74f071d3/*1]<br>
16:51:25.093|.\Extension.cpp(310)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.999: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=557136d88983dd36/999]<br>
16:51:25.109|.\Extension.cpp(310)|Log2||ExtnCfg::updateContact:[CM504001]: Ext.800: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=b462c9ed33f7ddaa/800]<br>
