All endpoints unregister every 60 minutes
Discussion in '3CX Phone System - General' started by MitchTheD, Dec 6, 2012.
  1. MitchTheD
    Dec 6, 2012
    I'm experiencing an agonizing problem where every 60 minutes, at 47 minutes past the hour, like clockwork, all of my Endpoints unregister, then re-register within the span of 2 or 3 seconds.
    This includes every system extension, such as ParkOrb, VMail, IVR - along with my extensions tied to physical voip phones. You can visually see all the extensions go red and become unavailable, in realtime. Needless to say, this is causing me great heartache.
    I'm using the paid version, v11 SP2.
    Any input would be deeply appreciated. I don't understand the behavior, though I'm pretty certain this not normal. I'm going crazy trying to track this down....
    Log snippet:
    06-Dec-2012 00:49:18.714 [CM504001]: Endpoint Extn:113: new contact is registered. Contact(s): [sip:113@192.168.130.100:5060 / 113]
    06-Dec-2012 00:49:14.995 [CM504001]: Endpoint Extn:111: new contact is registered. Contact(s): [sip:111@192.168.130.101:5060 / 111]
    06-Dec-2012 00:49:13.606 [CM504001]: Endpoint Extn:161: new contact is registered. Contact(s): [sip:161@192.168.130.104:5060 / 161]
    06-Dec-2012 00:49:13.039 [CM504001]: Endpoint Extn:205: new contact is registered. Contact(s): [sip:205@192.168.130.111:5060 / 205]
    06-Dec-2012 00:49:10.606 [CM504001]: Endpoint Extn:206: new contact is registered. Contact(s): [sip:206@192.168.130.112:5060 / 206]
    06-Dec-2012 00:49:05.041 [CM504001]: Endpoint Extn:202: new contact is registered. Contact(s): [sip:202@192.168.130.127:5060 / 202]
    06-Dec-2012 00:49:04.783 [CM504001]: Endpoint Extn:162: new contact is registered. Contact(s): [sip:162@192.168.130.115:5060 / 162]
    06-Dec-2012 00:48:55.731 [CM504001]: Endpoint Extn:201: new contact is registered. Contact(s): [sip:201@192.168.130.107:5060 / 201]
    06-Dec-2012 00:48:54.229 [CM504001]: Endpoint Extn:160: new contact is registered. Contact(s): [sip:160@192.168.130.122:5060 / 160]
    06-Dec-2012 00:48:52.080 [CM504001]: Endpoint Extn:151: new contact is registered. Contact(s): [sip:151@192.168.130.109:5060 / 151]
    06-Dec-2012 00:48:47.399 [CM504001]: Endpoint Extn:175: new contact is registered. Contact(s): [sip:175@192.168.130.125:5060 / 175]
    06-Dec-2012 00:48:44.165 [CM504001]: Endpoint Extn:203: new contact is registered. Contact(s): [sip:203@192.168.130.110:5060 / 203]
    06-Dec-2012 00:48:42.303 [CM504001]: Endpoint Extn:152: new contact is registered. Contact(s): [sip:152@192.168.130.113:5060 / 152]
    06-Dec-2012 00:48:40.617 [CM504001]: Endpoint Extn:163: new contact is registered. Contact(s): [sip:163@192.168.130.105:5060 / 163]
    06-Dec-2012 00:48:30.934 [CM504001]: Endpoint Extn:172: new contact is registered. Contact(s): [sip:172@192.168.130.118:5060 / 172]
    06-Dec-2012 00:48:29.705 [CM504001]: Endpoint Extn:141: new contact is registered. Contact(s): [sip:141@192.168.130.106:5060 / 141]
    06-Dec-2012 00:48:29.349 [CM504001]: Endpoint Extn:174: new contact is registered. Contact(s): [sip:174@192.168.130.121:5060 / 174]
    06-Dec-2012 00:48:28.659 [CM504001]: Endpoint Extn:110: new contact is registered. Contact(s): [sip:110@192.168.130.103:5060 / 110]
    06-Dec-2012 00:48:26.636 [CM504001]: Endpoint Extn:181: new contact is registered. Contact(s): [sip:181@192.168.130.126:5060 / 181]
    06-Dec-2012 00:48:25.466 [CM504001]: Endpoint Extn:180: new contact is registered. Contact(s): [sip:180@192.168.130.120:5060 / 180]
    06-Dec-2012 00:48:22.527 [CM504001]: Endpoint Extn:142: new contact is registered. Contact(s): [sip:142@192.168.130.108:5060 / 142]
    06-Dec-2012 00:48:20.592 [CM504001]: Endpoint Extn:170: new contact is registered. Contact(s): [sip:170@192.168.130.116:5060 / 170]
    06-Dec-2012 00:48:06.287 [CM504001]: Endpoint Extn:173: new contact is registered. Contact(s): [sip:173@192.168.130.119:5060 / 173]
    06-Dec-2012 00:48:06.092 [CM504001]: Endpoint Extn:171: new contact is registered. Contact(s): [sip:171@192.168.130.117:5060 / 171]
    06-Dec-2012 00:47:49.766 [CM504001]: Endpoint Extn:200: new contact is registered. Contact(s): [sip:200@192.168.130.128:5060 / 200]
    06-Dec-2012 00:47:19.240 [CM504001]: Endpoint Extn:140: new contact is registered. Contact(s): [sip:140@192.168.130.102:5060 / 140]
    06-Dec-2012 00:47:09.247 [CM504001]: Endpoint ParkOrb:SP0: new contact is registered. Contact(s): [sip:SP0@127.0.0.1:40000 / SP0]
    06-Dec-2012 00:47:08.166 [CM504001]: Endpoint Ivr:RecordFile: new contact is registered. Contact(s): [sip:RecordFile@127.0.0.1:40600 / RecordFile]
    06-Dec-2012 00:47:08.165 [CM504001]: Endpoint Ivr:playFile: new contact is registered. Contact(s): [sip:playFile@127.0.0.1:40600 / PlayFile]
    06-Dec-2012 00:47:08.157 [CM504001]: Endpoint Ivr:MakeCall: new contact is registered. Contact(s): [sip:MakeCall@127.0.0.1:40600 / MakeCall]
    06-Dec-2012 00:47:08.128 [CM504001]: Endpoint ParkOrb:*1: new contact is registered. Contact(s): [sip:*1@127.0.0.1:40000 / *1]
    06-Dec-2012 00:47:08.127 [CM504001]: Endpoint ParkOrb:*0: new contact is registered. Contact(s): [sip:*0@127.0.0.1:40000 / *0]
    06-Dec-2012 00:47:08.126 [CM504001]: Endpoint ParkOrb:SP7: new contact is registered. Contact(s): [sip:SP7@127.0.0.1:40000 / SP7]
    06-Dec-2012 00:47:08.126 [CM504001]: Endpoint ParkOrb:SP6: new contact is registered. Contact(s): [sip:SP6@127.0.0.1:40000 / SP6]
    06-Dec-2012 00:47:08.125 [CM504001]: Endpoint ParkOrb:SP5: new contact is registered. Contact(s): [sip:SP5@127.0.0.1:40000 / SP5]
    06-Dec-2012 00:47:08.124 [CM504001]: Endpoint ParkOrb:SP4: new contact is registered. Contact(s): [sip:SP4@127.0.0.1:40000 / SP4]
    06-Dec-2012 00:47:08.120 [CM504001]: Endpoint ParkOrb:SP9: new contact is registered. Contact(s): [sip:SP9@127.0.0.1:40000 / SP9]
    06-Dec-2012 00:47:08.114 [CM504001]: Endpoint ParkOrb:SP8: new contact is registered. Contact(s): [sip:SP8@127.0.0.1:40000 / SP8]
    06-Dec-2012 00:47:08.106 [CM504001]: Endpoint ParkOrb:SP3: new contact is registered. Contact(s): [sip:SP3@127.0.0.1:40000 / SP3]
    06-Dec-2012 00:47:08.097 [CM504001]: Endpoint ParkOrb:SP2: new contact is registered. Contact(s): [sip:SP2@127.0.0.1:40000 / SP2]
    06-Dec-2012 00:47:08.081 [CM504001]: Endpoint ParkOrb:*777: new contact is registered. Contact(s): [sip:*777@127.0.0.1:40000 / *777]
    06-Dec-2012 00:47:08.075 [CM504001]: Endpoint ParkOrb:SP1: new contact is registered. Contact(s): [sip:SP1@127.0.0.1:40000 / SP1]
    06-Dec-2012 00:47:07.766 [CM504001]: Endpoint Conf:704: new contact is registered. Contact(s): [sip:704@127.0.0.1:40300 / 704]
    06-Dec-2012 00:47:07.765 [CM504001]: Endpoint Conf:703: new contact is registered. Contact(s): [sip:703@127.0.0.1:40300 / 703]
    06-Dec-2012 00:47:07.765 [CM504001]: Endpoint Conf:702: new contact is registered. Contact(s): [sip:702@127.0.0.1:40300 / 702]
    06-Dec-2012 00:47:07.765 [CM504001]: Endpoint Conf:701: new contact is registered. Contact(s): [sip:701@127.0.0.1:40300 / 701]
    06-Dec-2012 00:47:07.754 [CM504001]: Endpoint Conf:700: new contact is registered. Contact(s): [sip:700@127.0.0.1:40300 / 700]
    06-Dec-2012 00:47:07.745 [CM504001]: Endpoint Ivr:IVRForward: new contact is registered. Contact(s): [sip:IVRForward@127.0.0.1:40600 / IVRForward]
    06-Dec-2012 00:47:07.735 [CM504001]: Endpoint Ivr:EndCall: new contact is registered. Contact(s): [sip:EndCall@127.0.0.1:40600 / EndCall]
    06-Dec-2012 00:47:07.729 [CM504001]: Endpoint Ivr:777: new contact is registered. Contact(s): [sip:777@127.0.0.1:40600 / 777]
    06-Dec-2012 00:47:07.725 [CM504001]: Endpoint Ivr:HOL: new contact is registered. Contact(s): [sip:HOL@127.0.0.1:40600 / HOL]
    06-Dec-2012 00:47:07.724 [CM504001]: Endpoint VMail:999: new contact is registered. Contact(s): [sip:999@127.0.0.1:40600 / 999]
    06-Dec-2012 00:47:07.707 [CM504001]: Endpoint Ivr:DialCode: new contact is registered. Contact(s): [sip:DialCode@127.0.0.1:5488 / DialCode]
    06-Dec-2012 00:47:07.355 [CM504002]: Endpoint Extn:174: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.355 [CM504002]: Endpoint Extn:203: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.354 [CM504002]: Endpoint Extn:162: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.354 [CM504002]: Endpoint ParkOrb:*0: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.354 [CM504002]: Endpoint Extn:181: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.354 [CM504002]: Endpoint Extn:170: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.353 [CM504002]: Endpoint Extn:163: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.353 [CM504002]: Endpoint Conf:703: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.353 [CM504002]: Endpoint Extn:171: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.353 [CM504002]: Endpoint Conf:702: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.352 [CM504002]: Endpoint Ivr:DialCode: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.352 [CM504002]: Endpoint ParkOrb:*777: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.352 [CM504002]: Endpoint Extn:175: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.351 [CM504002]: Endpoint Extn:111: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.350 [CM504002]: Endpoint Extn:205: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.350 [CM504002]: Endpoint Ivr:HOL: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.350 [CM504002]: Endpoint Extn:202: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.350 [CM504002]: Endpoint Ivr:777: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.349 [CM504002]: Endpoint Ivr:MakeCall: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.349 [CM504002]: Endpoint Extn:180: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.349 [CM504002]: Endpoint Extn:142: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.348 [CM504002]: Endpoint ParkOrb:SP9: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.348 [CM504002]: Endpoint Extn:206: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.348 [CM504002]: Endpoint ParkOrb:SP8: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.347 [CM504002]: Endpoint ParkOrb:SP3: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.347 [CM504002]: Endpoint Ivr:IVRForward: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.347 [CM504002]: Endpoint Conf:704: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.346 [CM504002]: Endpoint Ivr:playFile: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.346 [CM504002]: Endpoint ParkOrb:SP5: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.346 [CM504002]: Endpoint ParkOrb:SP7: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.345 [CM504002]: Endpoint Extn:200: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.345 [CM504002]: Endpoint Conf:700: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.345 [CM504002]: Endpoint Ivr:EndCall: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.344 [CM504002]: Endpoint Extn:151: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.344 [CM504002]: Endpoint ParkOrb:*1: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.344 [CM504002]: Endpoint ParkOrb:SP2: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.344 [CM504002]: Endpoint Extn:160: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.344 [CM504002]: Endpoint Extn:141: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.343 [CM504002]: Endpoint Extn:161: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.343 [CM504002]: Endpoint Extn:152: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.343 [CM504002]: Endpoint Extn:110: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.342 [CM504002]: Endpoint Extn:201: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.342 [CM504002]: Endpoint Extn:173: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.342 [CM504002]: Endpoint Conf:701: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.342 [CM504002]: Endpoint ParkOrb:SP0: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.341 [CM504002]: Endpoint ParkOrb:SP4: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.341 [CM504002]: Endpoint ParkOrb:SP1: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.341 [CM504002]: Endpoint Ivr:RecordFile: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.340 [CM504002]: Endpoint Extn:172: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.340 [CM504002]: Endpoint Extn:140: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.339 [CM504002]: Endpoint ParkOrb:SP6: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.339 [CM504002]: Endpoint Extn:113: a contact is unregistered. Contact(s): []
    06-Dec-2012 00:47:07.338 [CM504002]: Endpoint VMail:999: a contact is unregistered. Contact(s): []
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Check services status when this happens. Also activate verbose logging and check for any other usefull information when this event happens, like a service stoped or any exception occured. Check also Server event log for any warning message.
