All Extension's "Not Registered"
Discussion in '3CX Phone System - General' started by westek-consulting, Dec 8, 2009.
  1. westek-consulting
    Nov 30, 2009
    6
    I have a new client with a 3CX System and today he call's me to say none of his phones are working in his office. I have done the following preliminary diagnostics:
    Internet up and bandwidth @ 5mbps(as usual)
    Checked 3CX services and all are running
    Rebooted server 2 times - no effect
    I am new to 3CX and VOIP(for the most part), any ideas?
    Thank You Very Much,
    Kyle West
    Westek Consulting
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Was the server getting an IP address from DHCP instead of being a static IP? If so, the IP might have changed and now the phones can't find the server.
  3. Ricambi America
    Nov 10, 2007
    61
    When that happens for us, it is 99% of the time a STUN server issue.
  4. Ricambi America
    Nov 10, 2007
    61
    Yes, all of ours phones are outside the LAN, and indeed the stun server went down. We have switched from using the 3cx stun servers, that were unfortunately, not reliable.
  5. westek-consulting
    Nov 30, 2009
    6
    Static IP from AT&T.
  6. westek-consulting
    Nov 30, 2009
    6
    Here is this mornings log:
    08:36:11.929 [CM504001]: Ext.1199: new contact is registered. Contact(s): [sip:1199@99.67.45.250:15248/1199]
    08:35:49.397 [CM504008]: Fax Service: registered as sip:8888@192.168.1.13:5060 with contact sip:8888@192.168.1.13:5100;user=phone
    08:34:31.570 [CM503008]: Call(26): Call is terminated
    08:34:31.523 [CM503015]: Call(26): Attempt to reach <sip:4000@192.168.1.13:5060> failed. Reason: Not Found
    08:34:31.523 [CM503003]: Call(26): Call to sip:1109@3cx.uslawcenteronline.com has failed; Cause: 410 Gone; from IP:69.233.127.50:5061
    08:34:15.633 [CM503024]: Call(26): Calling RingAll4003:1102Ext.11021105Ext.11051106Ext.11061108Ext.11081109Ext.11091111Ext.1111@[Dev:sip:1109@69.233.127.50:5061]
    08:34:15.617 [MS210002] C:26.2:Offer provided. Connection(transcoding mode): 69.233.127.49:7020(7021)
    08:34:15.601 [CM503005]: Call(26): Forwarding: RingAll4003:1102Ext.11021105Ext.11051106Ext.11061108Ext.11081109Ext.11091111Ext.1111@[Dev:sip:1109@69.233.127.50:5061]
    08:34:15.586 [CM503015]: Call(26): Attempt to reach <sip:4000@192.168.1.13:5060> failed. Reason: Not Registered
    08:34:15.586 [CM503016]: Call(26): Target is not registered: RingAll4000:1111Ext.1111
    08:34:15.570 [CM503010]: Making route(s) to <sip:4000@192.168.1.13:5060>
    08:34:15.570 [MS210000] C:26.1:Offer received. RTP connection: 4.55.12.130:8760(8761)
    08:34:15.570 Remote SDP is set for legC:26.1
    08:34:15.570 [CM505003]: Provider:[SOTEL 19513710027] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:69.233.127.49:5060]
    08:34:15.492 [CM503001]: Call(26): Incoming call from 19492783229@(Ln.10001@SOTEL 19513710027) to <sip:4000@192.168.1.13:5060>
    08:34:15.336 [CM503012]: Inbound office hours rule (unnamed) for 10001 forwards to DN:4000
    08:34:15.336 Looking for inbound target: called=19513710027; caller=19492783229
    08:34:15.258 [CM500002]: Info on incoming INVITE:
    INVITE sip:19513710027@69.233.127.49 SIP/2.0
    Via: SIP/2.0/UDP 4.79.132.209;branch=z9hG4bK78c4.ebde83d2.0
    Via: SIP/2.0/UDP 4.55.12.163:5060;branch=z9hG4bK0dBe596402d72faf383
    Max-Forwards: 17
    Record-Route: <sip:4.79.132.209;lr=on;ftag=gK0d20f7f7;vsf=AAAAABoIDQ0LBQ8LAQALeXQaGwAbHwMcHwcFMzo1MDYwO2lzdXAtb2xpPTYx>
    Contact: <sip:+19492783229@4.55.12.163:5060>
    To: <sip:19513710027@4.79.132.209:5060>
    Call-ID: 453856692_70762192@4.55.12.163
    CSeq: 1903 INVITE
    Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay, multipart/mixed
    Allow: INVITE, ACK, CANCEL, BYE, PRACK, UPDATE
    Supported: 100rel
    P-Asserted-Identity: <sip:+19492783229@4.55.12.163:5060>
    Content-Length: 0
    08:34:10.867 [CM503008]: Call(25): Call is terminated
    08:34:10.586 [CM503024]: Call(25): Calling @[Dev:sip:MSExchange@192.168.1.10:5060;transport=TCP]
    08:34:10.570 [MS210002] C:25.3:Offer provided. Connection(transcoding mode): 192.168.1.13:7018(7019)
    08:34:10.539 [CM503005]: Call(25): Forwarding: @[Dev:sip:MSExchange@192.168.1.10:5060;transport=TCP]
    08:33:46.492 [CM503024]: Call(25): Calling RingAll4003:1102Ext.11021105Ext.11051106Ext.11061108Ext.11081109Ext.11091111Ext.1111@[Dev:sip:1109@69.233.127.50:5061]
    08:33:46.492 [MS210002] C:25.2:Offer provided. Connection(transcoding mode): 69.233.127.49:7016(7017)
    08:33:46.461 [CM503005]: Call(25): Forwarding: RingAll4003:1102Ext.11021105Ext.11051106Ext.11061108Ext.11081109Ext.11091111Ext.1111@[Dev:sip:1109@69.233.127.50:5061]
    08:33:46.430 [CM503015]: Call(25): Attempt to reach <sip:4000@192.168.1.13:5060> failed. Reason: Not Registered
    08:33:46.430 [CM503016]: Call(25): Target is not registered: RingAll4000:1111Ext.1111
    08:33:46.430 [CM503010]: Making route(s) to <sip:4000@192.168.1.13:5060>
    08:33:46.430 [MS210000] C:25.1:Offer received. RTP connection: 4.55.12.130:20698(20699)
    08:33:46.414 Remote SDP is set for legC:25.1
    08:33:46.414 [CM505003]: Provider:[SOTEL 19513710027] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:69.233.127.49:5060]
    08:33:46.367 [CM503001]: Call(25): Incoming call from 19492783229@(Ln.10001@SOTEL 19513710027) to <sip:4000@192.168.1.13:5060>
    08:33:46.102 [CM503012]: Inbound office hours rule (unnamed) for 10001 forwards to DN:4000
    08:33:46.102 Looking for inbound target: called=19513710027; caller=19492783229
    08:33:46.024 [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 4.79.132.209;branch=z9hG4bKdf51.508c6dd1.0
    Via: SIP/2.0/UDP 4.55.12.163:5060;branch=z9hG4bK04B9f714abf0be6df84
    Max-Forwards: 17
    Record-Route: <sip:4.79.132.209;lr=on;ftag=gK045611b4;vsf=AAAAABoIDQ0LBQ8LAQALeXQaGwAbHwMcHwcFMzo1MDYwO2lzdXAtb2xpPTYx>
    Call-ID: 453263612_20664697@4.55.12.163
    CSeq: 27302 INVITE
    Supported: 100rel
    Content-Length: 0
    08:30:49.183 [CM504008]: Fax Service: registered as sip:8888@192.168.1.13:5060 with contact sip:8888@192.168.1.13:5100;user=phone
    08:29:26.841 [CM503008]: Call(24): Call is terminated
    08:29:26.544 [CM503024]: Call(24): Calling @[Dev:sip:MSExchange@192.168.1.10:5060;transport=TCP]
    08:29:26.451 [MS210002] C:24.3:Offer provided. Connection(transcoding mode): 192.168.1.13:7014(7015)
    08:29:26.435 [CM503005]: Call(24): Forwarding: @[Dev:sip:MSExchange@192.168.1.10:5060;transport=TCP]
    08:29:02.420 [CM503024]: Call(24): Calling RingAll4003:1102Ext.11021105Ext.11051106Ext.11061108Ext.11081109Ext.11091111Ext.1111@[Dev:sip:1109@69.233.127.50:5061]
    08:29:02.404 [MS210002] C:24.2:Offer provided. Connection(transcoding mode): 69.233.127.49:7012(7013)
    08:29:02.389 [CM503005]: Call(24): Forwarding: RingAll4003:1102Ext.11021105Ext.11051106Ext.11061108Ext.11081109Ext.11091111Ext.1111@[Dev:sip:1109@69.233.127.50:5061]
    08:29:02.342 [CM503015]: Call(24): Attempt to reach <sip:4000@192.168.1.13:5060> failed. Reason: Not Registered
    08:29:02.342 [CM503016]: Call(24): Target is not registered: RingAll4000:1111Ext.1111
    08:29:02.342 [CM503010]: Making route(s) to <sip:4000@192.168.1.13:5060>
    08:29:02.326 [MS210000] C:24.1:Offer received. RTP connection: 4.55.4.130:8130(8131)
    08:29:02.326 Remote SDP is set for legC:24.1
    08:29:02.326 [CM505003]: Provider:[SOTEL 19513710027] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:69.233.127.49:5060]
    08:29:02.279 [CM503001]: Call(24): Incoming call from 19512317669@(Ln.10001@SOTEL 19513710027) to <sip:4000@192.168.1.13:5060>
    08:29:02.217 [CM503012]: Inbound office hours rule (unnamed) for 10001 forwards to DN:4000
    08:29:02.217 Looking for inbound target: called=19513710027; caller=19512317669
    08:29:02.139 [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 4.79.132.210;branch=z9hG4bK258b.eb3279a1.0
    Via: SIP/2.0/UDP 4.55.4.163:5060;branch=z9hG4bK04B01843ce4414e350b
    Max-Forwards: 26
    Record-Route: <sip:4.79.132.210;lr=on;ftag=gK041ecda3;vsf=AAAAABoIDAQDAQIGAQAPeXQaGwAbGhofBwUzOjUwNjA7aXN1cC1vbGk9NjI->
    Contact: <sip:+19512317669@4.55.4.163:5060>
    To: <sip:19513710027@4.79.132.210:5060>
    Call-ID: 235192393_57903250@4.55.4.163
    CSeq: 14374 INVITE
    Supported: 100rel
    P-Asserted-Identity: <sip:+19512317669@4.55.4.163:5060>
    Content-Length: 0
  7. westek-consulting
    Nov 30, 2009
    6
    The thing is, at sometimes 1-3 phones are registered. Last night I was able to call in and get the after hours voice recording, this morning that is no longer working.
    They have a Netgear POE switch, I believe it may be having a POE error. I am looking into that issue now.
    Could a POE error cause the same problems?
    Thanks everyone.
    Kyle
  8. KerryG
    Jun 19, 2009
    960
    If the phones are powering off that would be an issue. Use a softphone and see if it loses registration.
