All Extensions unregister and re-register
Discussion in '3CX Phone System - General' started by MorganM, Jul 25, 2013.
  1. MorganM
    Jul 25, 2013
    I'm having a problem on my 3CX box (v11.0.28976.849), every two to three hours all my extensions ( +-500 extension) unregister and re-register. Has anyone had this problem before? I cant see anything in the event log that might be the reason for this.
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    @MorganM
    This happens when phones do not refresh their registration sufficiently early to prevent the registration from expiring. Sometimes this can be accentuated by clock precision issues on the PBX machine (Virtual Machines particularly).
  3. leejor
    10,586
    252
    You don't say what type (make/model) extensions that you are using. I'm going to assume that they are all the same type. Many sets/ATA's will "obey" 3CX when it sets the re-registration time (30 minutes or less). Some require that you modify the settings manually, or in the configuration file)
