All phones drop incoming calls sometimes
Discussion in '3CX Phone System - General' started by oliverm, Aug 24, 2011.
  1. oliverm
    Mar 10, 2009
    79
    We have an issue whereby the phones will ring once and then stop. All the phones are in a ring group. We thought it was just someone hanging up before we could answer it. However sometimes these calls then get set to our answering service, which is done by a forward in 3cx.
    When we looked at the logs we see that 3cx reports that all four phones terminated the call at the same time, but no one did.
    Any ideas what this may be?
    Heres the logs
    All phones rejected incoming call
    11:37:21.140 Currently active calls [none]
    11:37:03.390 [CM503008]: Call(20): Call is terminated
    11:36:50.375 [CM503003]: Call(21): Call to sip:103@10.1.39.6:5060 has failed; Cause: 487 Request Terminated; from IP:10.1.39.29:2048
    11:36:50.359 [CM503003]: Call(21): Call to sip:100@10.1.39.6:5060 has failed; Cause: 487 Request Terminated; from IP:10.1.39.35:2048
    11:36:50.359 [CM503003]: Call(21): Call to sip:102@10.1.39.6:5060 has failed; Cause: 487 Request Terminated; from IP:10.1.39.28:2048
    11:36:50.359 [CM503003]: Call(21): Call to sip:101@10.1.39.6:5060 has failed; Cause: 487 Request Terminated; from IP:10.1.39.16:2048
    11:36:50.234 [CM503008]: Call(21): Call is terminated
    11:36:49.140 Currently active calls - 2: [20,21]
    11:36:48.500 [CM505001]: Ext.101: Device info: Device Identified: [Man: Snom;Mod: 3xx series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom320/7.3.14] PBX contact: [sip:101@10.1.39.6:5060]
    11:36:48.500 [CM503002]: Call(21): Alerting sip:101@10.1.39.16:2048;line=hpvk5vv5
    11:36:48.500 [CM505001]: Ext.100: Device info: Device Identified: [Man: Snom;Mod: 3xx series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom320/7.3.14] PBX contact: [sip:100@10.1.39.6:5060]
    11:36:48.500 [CM503002]: Call(21): Alerting sip:100@10.1.39.35:2048;line=j3b41cpk
    11:36:48.437 [CM505001]: Ext.102: Device info: Device Identified: [Man: Snom;Mod: 3xx series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom320/7.3.14] PBX contact: [sip:102@10.1.39.6:5060]
    11:36:48.437 [CM503002]: Call(21): Alerting sip:102@10.1.39.28:2048;line=bxp367tj
    11:36:48.312 [CM505001]: Ext.103: Device info: Device Identified: [Man: Snom;Mod: 3xx series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom320/7.3.14] PBX contact: [sip:103@10.1.39.6:5060]
    11:36:48.312 [CM503002]: Call(21): Alerting sip:103@10.1.39.29:2048;line=7on05cxi
    11:36:48.218 [CM503025]: Call(21): Calling RingAll800:100Ext.100101Ext.101103Ext.103102Ext.102@[Dev:sip:102@10.1.39.28:2048;line=bxp367tj]
    11:36:48.218 [MS210002] C:21.5:Offer provided. Connection(transcoding mode): 10.1.39.6:7088(7089)
    11:36:48.218 [CM503025]: Call(21): Calling RingAll800:100Ext.100101Ext.101103Ext.103102Ext.102@[Dev:sip:103@10.1.39.29:2048;line=7on05cxi]
    11:36:48.203 [MS210002] C:21.4:Offer provided. Connection(transcoding mode): 10.1.39.6:7086(7087)
    11:36:48.203 [CM503025]: Call(21): Calling RingAll800:100Ext.100101Ext.101103Ext.103102Ext.102@[Dev:sip:101@10.1.39.16:2048;line=hpvk5vv5]
    11:36:48.203 [MS210002] C:21.3:Offer provided. Connection(transcoding mode): 10.1.39.6:7084(7085)
    11:36:48.203 [CM503025]: Call(21): Calling RingAll800:100Ext.100101Ext.101103Ext.103102Ext.102@[Dev:sip:100@10.1.39.35:2048;line=j3b41cpk]
    11:36:48.203 [MS210002] C:21.2:Offer provided. Connection(transcoding mode): 10.1.39.6:7082(7083)
    11:36:48.187 [CM503004]: Call(21): Route 1: RingAll800:100Ext.100101Ext.101103Ext.103102Ext.102@[Dev:sip:100@10.1.39.35:2048;line=j3b41cpk,Dev:sip:101@10.1.39.16:2048;line=hpvk5vv5,Dev:sip:103@10.1.39.29:2048;line=7on05cxi,Dev:sip:102@10.1.39.28:2048;line=bxp367tj]
    11:36:48.187 [CM503010]: Making route(s) to <sip:800@10.1.39.6:5060>
    11:36:48.187 [MS210000] C:21.1:Offer received. RTP connection: 83.218.143.18:32484(32485)
    11:36:48.187 Remote SDP is set for legC:21.1
    11:36:48.187 [CM505003]: Provider:[Spitfire] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:441273907880@109.238.76.251:62445]
    11:36:48.156 [CM503001]: Call(21): Incoming call from 01273719594@(Ln.10000@Spitfire) to <sip:800@10.1.39.6:5060>
    11:36:48.046 [CM503012]: Inbound specific hours w/o holidays rule (441273907880) for 10000 forwards to DN:800
    11:36:48.046 Looking for inbound target: called=441273907880; caller=01273719594
    11:36:48.046 [CM500002]: Info on incoming INVITE:
    INVITE sip:441273907880@109.238.76.251:62445;rinstance=ce804627bcd7baea SIP/2.0
    Via: SIP/2.0/UDP 83.218.143.18:5060;branch=z9hG4bK-d87543-037a890f6b49492953f3-1-cHBiNWM0Y2E1YzZlMmNhZTZjNGY3Yg..-d87543-
    Max-Forwards: 15
    Contact: <sip:CqIgJwaIDiqTyU0B1MKPEKaTpjNiK4vnuXqMEd7SgCdC_mA5iVrd9GXUh4zQO2agECWU9qPEsQTO3c9MjtqPTI7Yz0xO2Q9MT4@83.218.143.18:5060>
    To: <sip:441273907880@83.218.143.18>
    Call-ID: 9beaad0913b4a12b8a2098ca6d73d6f6
    CSeq: 500542371 INVITE
    P-Asserted-Identity: <sip:01273719594@217.13.128.46:5060>
    Content-Length: 0
    Remote-Party-ID: <sip:01273719594@217.13.128.46:5060>;party=calling;screen=yes;privacy=off
    X-Remote-Info: sip:217.13.128.46:5060;transport=UDP, sip:83.218.143.99:5060;transport=UDP
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi. we could resolve this for you, however a small fee of £25.52 would be payable and for this we would login and investigate and if we where not able to fix, we would offer you a full refund.
    if you would like us to do this for you, please click the below link
    http://www.3cx-phone-system.co.uk/3cx-support/pay-as-you-go-support.html
    We could have this fixed today.
