All simultaneous calls are in use
Discussion in '3CX Phone System - General' started by David Bratty, May 17, 2017.
  1. David Bratty
    May 17, 2017
    What happens when a call comes in and all simultaneous calls are in use?
    Does the call go to voicemail? Is there a setting within 3cx to specify what happens to that call?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,302
    530
    Hello @David Bratty
    When the license reaches the limit the next call is dropped and the caller hears a prompt that the limit is reached. There is no way to specify what happens to the call
  3. David Bratty
    May 17, 2017
  4. TechJimF
    May 11, 2017
    23
    Do internal, extension to extension calls count against simultaneous calls?
    Thanks,
    Jim
  5. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    yes
