All voicemails changed to default after ver 12 upgrade
Discussion in '3CX Phone System - General' started by rmayer, Jun 12, 2014.
  1. rmayer
    Jan 7, 2010
    58
    I recently did an upgrade from version 11 to 12 and now everyone's voicemail has changed to the system default prompt. Is there a way to change all extensions back to their recorded prompt? We have about 150 extensions, so going one by one would be tedious.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    178
    Each person can set to the saved greeting using 3cx phone for windows.
    Or you could find a way to script it. I think an XML file is created in the individual's directory. Set 1 and Copy it to each extension that has a previous greeting.
    (I am not in front of a system at the moment to tell you the voicemail path)
    It would have been nice if 3cx automatically set them as default when importing a v11 backup
