Solved All Yealink Phones No Longer Connecting to GCE Hosted 3CX
Discussion in '3CX Phone System - General' started by Brett Coleman, Nov 16, 2017.
  1. Brett Coleman
    Jun 20, 2017
    27
    Overnight all of our 40+ desk phones stopped working. We have mostly a mixture of T32G and T48G.
    All of them connect using a SBC running on a Windows server. I have rebooted the server and also restarted all services on the 3CX managment console. Everything is green and running.
    I am concurrently checking to see if the WAN/Firewall group has made any changes.
    What other things should I be checking?
    Thanks in advance.
  2. StefanW
    Jun 2, 2009
    1,199
    79
    is the IP the same as before? Do you static IPs in google? Can you access the 3CX MMC?
  3. Brett Coleman
    Jun 20, 2017
    27
    Yes to static IP and full access to the MMC. I can see that phone and pc clients are connected.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Check the IP blacklist of the PBX located on the dashboard in case your remote locations IP is blacklisted.
  5. Brett Coleman
    Jun 20, 2017
    27
    Looks like a firewall issue. Phones are all back online.
  6. YiannisH_3CX
    May 10, 2016
    4,443
    282
    Glad to hear the issue is resolved
