allo.com PRI gateway
Discussion in '3CX Phone System - General' started by telis, Jul 21, 2014.
  1. telis
    telis New Member
    Aug 13, 2007
    158
    28
    http://allo.com/pri-voip-gateway.html
    Has anyone come across this product? Any success configuring it with the 3CX system? From anyone at 3CX on the off chance are there any plans for the product to be added to supported hardware?
    It looks like a good product and is competitively priced.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    I'd suggest posting this as a feature request on 3CX Ideas : http://www.3cx.com/ideas
