Allow a user to see only their calls in the web reports GUI
Discussion in '3CX Phone System - General' started by impala, Jan 28, 2015.
  1. impala
    Sep 30, 2013
    Is there a way to give a user access to the web reports GUI without allowing them to see all other users calls as well?
    Thanks,
    Doug Mortensen
    Impala Networks
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Re: Allow a user to see only their calls in the web reports
    Hi there,
    Unfortunately, you can only allow access to all reports, with restricted access to the maintenance menu and to the call audio recordings of others.
    Kindly post this as a feature request on 3CX Ideas : http://www.3cx.com/ideas
