Allow csv importing of contacts
Discussion in 'Ideas' started by The Baldy, Jun 30, 2016.
  1. The Baldy
    Jun 28, 2016
    6
    Could we have the ability to import contacts in the address book via csv.
    Currently we can on sync via 365 or Google but i'd like to be able to export my contacts from my old soft phone and then import the data into 3CX.
