Allow custom labels for all button/key types
Discussion in 'Ideas' started by positron, Mar 16, 2017.
Allow custom labels for all button/key types 5 5 14votes
5/5, 14 votes
Tags:
  1. positron
    Jan 14, 2013
    76
    11
    On phones like the Yealink T4x series and others which allow labeling of buttons via programming instead of paper inserts, it would be desirable to control the assigned label for all button types. Currently, you can only manually assign the display label on the BLF tab of the extension if the button type is "custom speed dial"; other buttons are automatically labeled according to system name, extension name, feature code, etc.
    I would like to be able to choose to override system assigned names and use my own. For example, creating a key for Shared Park 0 automatically labels the key "SP0", but I would like to assign my own (more meaningful) description instead.
    craigreilly likes this.
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    I agree, and the shared park is where I would use it the most too !
  3. JMK
    JMK
    Jan 2, 2018
    34
    I agree. PARK should say PARK not SP
  4. Phone systems NZ
    Feb 15, 2017
    54
    17
    yes this would be very useful. On a Fanvil phone is you assign a line key it calls it <extn no.> | Fanvil X4 which really does not indicate it's a line key.
  5. Ashley1973
    Sep 7, 2018
    Would like to see this too especially for Line Keys which I would like to label LINE 1 and LINE 2 and park keys PARK 1 and PARK 2. Nobody knows what the system labels mean.
