Allow fax over WAN
Discussion in 'Ideas' started by CCAdmin, Mar 15, 2018.
Allow fax over WAN 5 5 13votes
5/5, 13 votes
  1. CCAdmin
    Feb 13, 2013
    66
    7
    I recently battled with getting my 4114 working on the newest v15.5.
    One thing I found was that you are blocking FAX extensions over the WAN.
    With more and more people moving to hosted PBX solutions, it makes no sense
    to block anything over the WAN and not at least give a way to unblock it.
    I had FAX extensions assigned to the 4114 and was getting the error "SIP request (REGISTER) from {my.internet.IP} was rejected. Reason: Block WAN requests is ON". I changed the extension from a FAX to a normal user extension, unchecked the 'disallow use...outside the LAN' box, and it started working finally.
    We need to be able to use FAX extensions over the WAN as well.
    Alroger Gomes Jr, Lev and craigreilly like this.
  2. joec
    Feb 23, 2018
    6
    I would also like to know how to do this. What fax server software are you using?
  3. Lev
    Lev New Member
    Sep 19, 2015
    119
    17
    Alroger Gomes Jr likes this.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,311
    249
    He is asking about 3cx Fax Extensions using ATA. So in this case, no Fax Server.
  5. Alroger Gomes Jr
    Jan 19, 2018
    8
    +1 here as well
    We just sold our first 3CX solution and now have this to stumble upon.
    We could just use a regular extension for connecting the ATA from outside the LAN, but it seems that this way there is no option of FAX pass-through, and it defaults to T.38 which our SIP Trunk doesn't have.
    Ohhhh boy.
    UPDATE: The extension Option PBX Delivers Audio seems to help. I have to try sending faxes now.
    #5 Alroger Gomes Jr, Jun 22, 2018
  6. Alroger Gomes Jr
    Jan 19, 2018
    8
    I take it all back.
    Seems to work fine using FXS/DECT (I used the supported Welltech from the list although I'm using a Grandstream HT802, just need to enter sip server, user and password to configure both FXS ports) and a regular extension with Pass-through FAX and specifying the FQDN as the network interface in the extension's phone provisioning.
  7. Lev
    Lev New Member
    Sep 19, 2015
    119
    17
    I might also try that one out, if i find some sparetime.
    But it is still just a workaround.
  8. Maykel Constantin
    May 25, 2018
    32
    how can you setup the HT802 to the 3cx please can you help me ?
  9. Alroger Gomes Jr
    Jan 19, 2018
    8
    I described exactly what I did! And now 3CX supports the HT802 (new update today).
  10. Maykel Constantin
    May 25, 2018
    32
    i know but cant download the .xml file 3cx never create the file.. so i cant download it..
  11. Alroger Gomes Jr
    Jan 19, 2018
    8
    I didn't download anything. It's already in 3CX.
  12. Maykel Constantin
    May 25, 2018
    32
  13. craigreilly
    Feb 1, 2012
    3,311
    249
    If the link to the config file is not working from step 7.3 then you may have bigger issues.
    You do not mention 3cx on same LAN or Cloud.... that would be a big consideration here.
  14. Maykel Constantin
    May 25, 2018
    32
    Cloud, not on the same LAN when i try to save the file i get:
    403 Forbidden
    nginx
  15. craigreilly
    Feb 1, 2012
    3,311
    249
    https vs http ? usually that is a 403 error.
    We do not know what your link looks like - public or private...
