Allow intelligent call control via Win10 popup
Discussion in 'Ideas' started by tim942, Feb 29, 2016.
  1. tim942
    Jul 30, 2015
    68
    6
    I came across a bug with 3CX for Windows and Windows 10 where the notification pop-up sends a "CALLEND" command via CTI whenever "DECLINE" is pressed, regardless if you are idle or on a call(thus ending the active call on the deskphone). "DIVERT TO VOICEMAIL" does not send the "CALLEND", but would not be best for all situations. It would be best if it would trigger the "REJECT" that is already available on Yealink Phones
