Allow Modifying supported phone template changes in gui
Discussion in 'Ideas' started by netswork, Jul 26, 2017.
  1. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Would like to be able to modify some simple items in the phone template via gui. Things on yealinks such as the time format and the display of the extension rather than the name on the phone. Being able to modify the dial plan of the phone as to not have to hit the "send" button on the phone display would be very helpful as well. Turning off the "screen saver" on the phones. This way we can modify the phone templates in a supported manner.
