Allowed Country Codes
Discussion in '3CX Phone System - General' started by Drew9213, Dec 6, 2017.
  1. Drew9213
    Sep 16, 2015
    62
    I'm working on a phone system that was installed by someone else and they did not install all of the country codes during the install of 3CX. I need to add these codes but am unable to find them anywhere in the management console. I'm running version 15.5. Anybody know where I can add these without having to do an uninstall/reinstall process? Thanks.
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Settings | Security | Allowed Country Codes
