Allowusebusyoptforgroup
Discussion in '3CX Phone System - General' started by vectra, Apr 29, 2016.
  1. vectra
    Nov 3, 2009
    28
    Hi Everyone,
    How to enable allowusebusygroup option in hosted multi tenant version of 3CX? There is no parameters menu in this version of 3CX.
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    442
    73
    This came up in the 3CX Ideas forum instructions are below. This isn't in 3CX Management console on multi tenant but you can do it with postgres client tool. Make sure to restart 3cx services after making the change:
    Postby nickybrg » Mon Apr 25, 2016 11:39 am
    You can connect via pgadmin (postgress client tool) and change the parameters from there. Custom parameters is disabled for security purposes from cloud instances.
  3. vectra
    Nov 3, 2009
    28
    How? Do you have any link or some instruction what to do?
