Alt-N outlook connector and 3cx on one system
Discussion in '3CX Phone System - General' started by Elmer, Oct 29, 2007.
  1. Elmer
    Oct 17, 2007
    Hi there,
    is there anybody that has the 3cx system running on a machine which also has alt-n's mdeamon and the outlook connector installed?
    My experience; extensions cannot be connected to 3cx, neither can a spa3012 (fxo nor fxs), but voipbuster can ?? No incoming calls in the 3cx log, softphones give " 500 internal server error " as feedback...
    When outlook connector is de -installed, 3cx works as usual. I will mail this issue to Alt-N as well, but maybe one of you guys can help me out?
    Thanks,
    Elmer
  2. rnoguera
    Oct 25, 2007
    89
    I have both them installed on 2003 Server SP2 and 3CX is working correctly...
    Outlook was installed first, but we seldom don't use it. Both are latest versions (Outlook Conector is 2.1.5, 3CX is 4 Alpha).
