Always have 2 active calls
Discussion in '3CX Phone System - General' started by Abbid, Nov 1, 2013.
  1. Abbid
    Nov 1, 2013
    I'm looking for some help.
    We're currently using the free licenses for 3cx.
    Our server logs always show 2 active calls being counted towards the license limit. The logs show:
    Active calls counted toward license limit: [230,305] .
    Is there anyway i can see where 230 and 305 are being used?
    None of the extensions are on calls and yet the logs show two active calls constantly.
    Do you guys have any ideas?
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Those numbers are call numbers, not extensions. You can then filter the log by the call number to see what was going on.
  3. Abbid
    Nov 1, 2013
    Thanks for the reply Ian,
    That can't be numbers because when we get a call in (looking at a live call right now) the number i have in the logs is 660 but thats not the call number at all.
    If what your saying is correct, then that means i always have 2 active calls but i cant see them anywhere. None of the extension show as connected, neither do any of the ports/trunks.
    Its becoming an issue because its eating into our 4 call license limit and getting 2 "real" calls in causes a license limit reached error for everyone else.
    Any ideas?
  4. way
    way
    Feb 21, 2011
    49
    Hello
    Have you checked the system extensions status as well?
    By going into the Server Activity logs tab, you can also see exactly what is handling those calls by clicking on on 'filter by call' and selecting the active calls (230 and 305). From there, you'll be able to see the call setup and exactly which extensions are currently on a call.
