an error has ocured in ivr
Discussion in 'Windows' started by mtaks09, May 14, 2010.
  1. mtaks09
    Dec 7, 2009
    22
    i get this message if the 8001 or digital reception answres call if i send it to an extention it rings just fine any ideas
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    In regards to IVR errors you can check the following link which I am sure it will assist you, please not that altough it says IIS it works with cassini aswell but you must ignore some parts of the document related to IIS.
    Code:
    http://www.3cx.com/blog/docs/troubleshooting-iis-ivr/
  3. mtaks09
    Dec 7, 2009
    22
    sorry man i looked at that page and cant make scince of it I am not very technical just learning as i go and that stuff looks way over my head you must be a lot smarter than i thanks for trying to help
  4. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    This will happen if the cassini or IIS web server service has stopped working.
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
    The better way is to open support ticket.
