An Error Occured in IVR Session - v9 / VAD v2.0
Discussion in 'CRM / Helpdesk / App Integration' started by mce, Jul 12, 2010.
  1. mce
    mce
    Jul 12, 2010
    "An Error Occured in IVR Session"
    when trying to call a Callflow that has been created with a VAD 2.0 from a remote machine (the VAD is not running on the 3CX server), I get the above mentioned spoken error message - and could not find a solution in this forum.
    This is the part from the 3CXIvrServer.log:
    22:54:43.606|2648|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://192.168.1.212:5481/ivr/(S(1dhtc345v1ubjs55ms4bv4ay))/TEST001_10/Main.vxml?dr=600&to=600&from=500MethodGETError-500
    22:54:43.606|2648|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc2
    22:54:43.606|2648|(0):Error! Module '3CX.com.vxi'. Error ID 203. uriTEST001_10/Main.vxml?dr=600&to=600&from=500
    22:54:43.606|2648|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    The 3CX is v9 and running on a Server 2003 machine with the Abyss webserver. Are there any solutions to this?
    Thank you
    -MCE
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    When deploying to Abyss Web Server, you need to specify the right port in the deployment URI, which is configured for IIS by default.
    To do this, open your VAD project, and select the project in the "Project Explorer Window". Then go to the "Properties Window", and check the following properties:
    PbxDeploymentUri=http://PBX_SERVER:5481/ivr/VAD_Deploy.aspx
    PbxDownloadDebugFilesUri=http://PBX_SERVER:5481/ivr/VAD_DownloadDebugInfoFile.aspx
    PbxGetDebugFileNamesUri=http://PBX_SERVER:5481/ivr/VAD_GetDebugInfoFileNames.aspx
    Please, verify those values and deploy the project again after adjusting them.
    Let me know if this works.
    Thanks,
  3. mce
    mce
    Jul 12, 2010
    works, thanks a lot!!
  4. VAD_Support
    Aug 6, 2009
    690
    Thanks for letting me know.
    We're working on a change for that configuration. You will only need to set up the web server you're using (Abyss, IIS or Cassini), and then everything else will be automatically set up. We hope to release a new version with this an another fixes in a few weeks.
  5. Gogie
    Aug 25, 2010
    I'm new and the proposed solution did not work at my place.
    I still have to use PbxConfigurationPort 5485?
    I tried it in version 8 and 9 with VAD2 same result
    Is this mentioned update already available
    TX
  6. VAD_Support
    Aug 6, 2009
    690
    The configuration port is 5485 by default, you don't need to change that.
    But depending on the WebServer used (IIS, Cassini or Abyss), you may need to change the deployment uri parameters. For example, to make it work with Abyss you need to enter something like this:
    If you're using another web server, those uris are different. Take a look at the user's manual for details, or let me know what web server are you using and I'll give your the right uris.
    Also, if you're deploying the project remotely, you need to allow remote access to the configuration. How to do this is also explained in the user's manual.
