"An error ocurred in IVR session, sorry"
Discussion in '3CX Phone System - General' started by scythe000, Feb 28, 2012.
  1. scythe000
    Nov 8, 2011
    66
    So, we have a re-ocurring issue, where about once a month, we have to reset the 3cx server as the voicemail stops functioning. Everything else is fine, although when i try to remotely connect to the admin page i get "An exception occurred LoginForm Error: Config server is not connected". Any thoughts? running version 9.
    10,360
    226
    Operating system? Hardware? Other applications running?
  3. scythe000
    Nov 8, 2011
    66
    Windows Server 2003, No other applications at all.
    Dual Core Pentium E5300 @ 2.6Ghz, 2GB Ram, 150GB HDD, Polycom SP IP430 phones, Sangoma Netborder Express Gateway.
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    I have observed similar behavior after Windows has installed an important update and then rebooted the system. In my case, there appears to be a hung application that shows "starting" in the services section. I have to end the application and restart using the services tab as the configuration service, which has not started, is required to be up and running before you can log into 3CX. There is a dependency between the 3CX phone service and the 3CX phone configuration service. You might check and see if any of the dates correlate to when Windows did an update and see.
    In my case,the phone system is down. I don't know that your situation is the same as mine since you indicated all else is running, which surprises me given the configuration services message.
  5. scythe000
    Nov 8, 2011
    66
    Hmm, I'm thinking this is different as I have the server set to manual updating only, and I checked services and all were started.
  6. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    That message is usually when the web service has stopped
  7. scythe000
    Nov 8, 2011
    66
    The IVR error? Really?
  8. KerryG
    Jun 19, 2009
    960
    Yes, really
  9. scythe000
    Nov 8, 2011
    66
    Ok, cool. I'll keep an eye out for that. Any idea why it would have stopped? What's the exact service name, do you know? When I had looked at it, I thought all the services labeled 3cx were running, but maybe i missed it.
  10. KerryG
    Jun 19, 2009
    960
    Depends on if you are using IIS or Abyss, look for a web server service.
